I doubt your dealer would ever notice the wiring. Take a look at the pic, the wiring would be invisible, and the dealer isn't going to go looking for it either. Drill out the center. If everything still works it will be fine. When you are done with the car you can pull the wire back out and nobody will know the difference. I'm guessing this isn't in the faq section because it was just posted this morning
The only way I see you having any problems is if you messed up and broke the harness while drilling, so if you are careful and patient there won't be a problem
DO IT!!!
