The Sport's at the shop, so really this is just academic, but I feel stupid for capitulating (I need the car fixed ASAP to get to work). The car's a Duratec with 80k on the clock.
Leaving work yesterday I started the car (sat outside all day in the cold). Normally it revs up to 1500 then settles back down to 1000 before I drive off. This time it revs up to 2000, drops to 1000, then fluctuates up and down until it sputters and almost stalls. It recovered back up to 1000 and ran just fine for the drive home. This morning it started normally. However, about 5 minutes on the road and the CEL went on. No problem, I thought, I'll hook up my laptop this evening. After work I went to start it; it revs up to 2000, then drops below 1000, sputters and dies. Every subsequent start would repeat the procedure. When the tow truck finally arrived (thank God for AAA) it decided to run long enough to pull out of the parking space and pull behind the flatbed.
I keep trying to troubleshoot this in my head, but I'm certainly not experienced enough of a mechanic. All I know is air/fuel/spark. If I hold the throttle it runs fine, it only has problems idling: IAC? I just replaced it this past spring. I noticed a strange smell when it was sputtering, maybe gasoline? I've heard from more than a couple people recently that there's an epidemic of fuel injector problems due to bad gas in the area. The tank is full, so I'm not sure its the pump. I replaced the plugs about two years ago with Autolite APP764s. I replaced a set of Bosch wires a few months ago because of hesitation with some OEM wires which solved that problem. If its spark, could it be the coil? I know having the CEL would certainly help here, but like I said I have to get it fixed ASAP to get to work. If this had happened a month ago I'd still have the SVT to take to work
