#1129585 12/13/04 10:36 PM
SVT_22 Offline OP
I have a '98 SVT w/ about 83k on it. Lately when i start out in the morning its really cold out now b/c i live in south west Wisconsin. But this morning when i start out and went from 1st to 2nd it grinded but in no other gears. Then i started out again and it did it again.. But never did it again. Until i left school and my first 1 2 shift it did it but, the second time it didn't, but then the third time it did and that was it.. Is this just the weather or what??
'98 CSVT T-Red: K&N High Flow,Ford Racing 9mm wires,OMP STB,Fidanza short shifter,OEM High Flow MAS,Autometer Phantom Gauges,Magnaflow Resonator no Mufflers '01 400EX: some mods!!
#1129586 12/13/04 11:11 PM
ah the common MTX-75 syncro problem. Your 2nd gear syncro is going out... Unless you are getting lazy with the clutch...
#1129587 12/14/04 04:19 AM
SVT_22 Offline OP
so where would i get a new syncro at?
#1129588 12/17/04 03:16 AM
Hi I bought a 96 SE on ebay and had a bad 3rd gear syncro.Its a big job,book call for 12 hours just for r&r tranny.I had about 20 hrs total time.You have to disconect a whole lot of stuff and drop the front frame while supporting the engine.Unless you have a place and the experince to do it id take it some where.I got an estimate of $1200 to fix it.That was mostly labor,only about $80 for the part.
#1129589 12/17/04 03:47 PM
If you have not already done so, change the trans fluid. ATF+3 works exceptionally well. You may find enough of an improvement that you can put off the trans repairs for a long time if ever.
Harder shifting when cold is somewhat of a product characteristic and may never go away, even with a normal overhaul.
