#1125307 12/08/04 08:29 PM
I have a problem with my dome light. The little casing rail that holds it up there has cracked and broken which I believe was from the summer heat. The dome light is no longer up there. There are 2 phillips screws holding the rail up to the roof of the car.
My problem is I cant get them out. They seem to be stuck. Has anyone had this problem or have a suggestion as to getting them out?
White 95 GL ATX 56K Miles on it. Optilux By Hella Fog lights (The Angel Eyes) Driven hard, Just like I like it!
#1125308 12/08/04 09:08 PM
Do you have a picture of what it is your looking at? It might help you get some conclusive asswers.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
#1125309 12/08/04 09:15 PM
N
N
stuck as in just turn and nothing, or stuck as in don't turn at all?
#1125310 12/09/04 02:34 AM
Cant turn at all. Almost stripped the head trying to get them out.
As for the pic if you take out the dome light, its a 95 GL what i have, so if you take yours out it should hopefully look the same. Its just 2 screws that are up there.
#1125311 12/09/04 02:39 AM
N
N
I don't wanna sound stupid but do u use the right tool? Good phillips size? As you said the trim is already broken so you can cut the two notches just besides the srews and remove the trim pulling backway. Try using loose nut for the srews.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
