ok maybe you do stand a chance... so you have an '01+ 3L? which is not the same motor pictured above...
the crank bushing on the flywheel side needs to be cut off, the ear by the alternator needs to be cut off, two holes in the oil pan need to be relocated to line up with the tranny, use exhaust manifolds from old motor, swap over timing cover, swap on powersteering pump, swap on passenger side motor mount, relocated iac, modifiy tube for the egr, modify tb bracket, get a hold of an svt/atx tb cable, find a way to braze/modify the fuel rail to returnless... do you have the motor/trans assy pulled yet??
