#1125001 12/08/04 05:35 AM
I just bought a 98 contour se, 2.0 atx.
got the oil changed today, and I was told that they can only get 3.0 quarts in, otherwise the dipstick says there is to much. He asked me if my oil pan had a dent in it, while the other guy underneath said it didn't. Has anyone else had this problem, or know what else to look for before I take it to my reg. mech.
#1125002 12/08/04 03:30 PM
unless the oil pan is filled with sludge then it should take 5 qts of oil with out an issue
#1125003 12/08/04 03:51 PM
N
N
How much oil came out when they changed it?
#1125004 12/08/04 09:17 PM
when I bought the car, of course I checked the oil, and it looked good. The dealer did an oil changed before I took it home, and recently I checked it again, and it was overfull. they got the right amount out, but the right amount in was to much. How hard is it to drop the oil pan, and check that out?
#1125005 12/08/04 11:34 PM
E
E
Dropping the pan is not the hard part as there are only, IIRC, twelve bolts holding it on. Getting it out of the car is the difficult task. The exhaust system, at least from the flex pipe forward, has to be removed. The engine must be lifted to be able to wiggle the pan from between the subframe and the oil pickup.
I would suspect more that the car has the wrong dipstick because two quarts of sludge would be hard to accumulate, even with poor maintence.
· Jon Miconi · Coming Soon! · 01 Cougar · 98 V70R
#1125006 12/09/04 01:21 AM
as silly as this sounds, could someone do me a favor and measure their oil dipstick, so I could compare? 98 2.0 atx.
#1125007 12/09/04 05:04 AM
The pan would have to have a huge dent to displace 2 quarts.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1125008 12/09/04 05:51 AM
I think an aluminum pan would crack before it would dent.
Could it have a load of sludge in the crankcase that won't drain out? That would be really bad news.
#1125009 12/09/04 05:52 AM
They probably forgot to drain oil out.
99 Black SVT -3L Hybrid w/.5mm overbore, Spec clutch/flywheel, MSDS, BAT intake, K&N open, 17'Konig Tantrums, DMD, Opt. TB & Y, Powerslots, Bassani w/ magnaflow res. 96 SE MTX- "The War Wagon" "I'm in love with my car..." -Queen
#1125010 12/13/04 05:34 AM
anyone get a chance to do this yet?
