#1124909 12/08/04 03:23 AM
I tried to change my oil once (whoopie!) and I used the wrong socket maybe, stripping the head of the oil plug slightly. My questions are:
What can I use now that sockets sorta dont work all the time to tighten/loosen the plug?
Where could I find a replacement?
I don't know if this is troubleshooting or not, but it's just a general thing. Thanks for any help
1999 SE White AVH-P6500DVD Infinity Reference 6500CS Pioneer 5x7s Punch 360a2 Punch 500a2 Adire Tempest in a custom sealed 3.4cuft box Modded Xbox Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
how about a pipe wrench(small one) one that will bite down into the metal and grab it without it slipping.. go to ford and get a new one and then use (if i can remember correctly) a 15 mm box end wrench on it.. make sure you are turning it to loosen it and not tighten it.. pretty common error when upside down people tend to go the opposite direction, forget which way they are turning due to the upside down position???? hope this helps.
W
W
Any auto parts shop, even Ford....
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
Also, use a 6-point socket or box end wrench instead of 12-point. Less chance of rounding off the head. This is after you go to the dealer and get a new drain plug and use vicegrips or channelock pliers to remove the old one.
can use a flat file and file down two new flats opposite each other (down to a standard wrench size.) I've done this before. The bolt is not all that hard.
When I did my first oil change, the oil place that last did it torqued it down too far. I couldn't get it off and ended up stripping the bolt. I was finally able to get it off with vice grips. Vice grips will indefintely get that sucker off, but do remember, it's all about leverage.
You can get a replacement bolt from anywhere. If you have another mode of transportation, get the bolt off, take it to a auto store/dealer/even an oil change place. (Once they see the bolt, they'll match up the neccessary thread pattern in no-time). I got mine through an oil change place. They charged me like $3.99, about the same price at any auto store.
Good luck!
99 Black Contour SE Sport
N
N
Yeah, vise grips will work well, but I think they also make a socket (craftsman tools) that is made for stripped nuts and bolts.
~~~ 99 Contour SE ATX 2.0 ~~~ ~~~ 98 Mystique GS ATX 2.0 ~~~ ~~~ 94 Civic DX HB MTX 1.5 ~~~ ~~~ 91 Toyota MR2 MTX 2.2 ~~~
