#1122425 12/06/04 07:13 AM
H
H
ok i need help really bad here guys/gals i have a 98 svt contour and i recently have got a carbon fiber hood and my latch won't work all together, so i need to install hood pins. please help me on this and send me or just whatever some instructions to me or anything you can.
i am not about the whole idea of putting holes in my new CF hood but if i have to i will.
i keep thinking to myself measure twice drill once.
but i need help by all means. where to put the pins and how to put them, how to mark my hood and where to drill.
anything thanks guys
#1122426 12/06/04 08:28 PM
W
W
I will be watching this thread w/ interest, because my CF Cowl hood is on the way.
Why doesn't the latch work??? Just didn't line up?
Where did you get yours????
Your making me nervous!
Wijn
1998 tour Zetec B&G springs cut 1" 17" Amp "tech-9" rims Pro tint 2 1/4" exhaust Autometer tach & Euro Guages CTA/weapon R combo intake Zex Dry Nitrous kit
#1122427 12/06/04 10:16 PM
H
H
i got mine off of ebay for like 230. yeah the latch didn;t line up at all so i took it off and my hood fit like perfect when the latch was off. so hood pins it must be.
#1122428 12/07/04 03:11 PM
If you are completly ditching the latch, get locking hood pins. I believe most autoparts places carry them, check around. Alot of the locking ones also have a lower profile and IMO look better anyway. Basicly all you need to do is decide on your under hood location, probably close to the adjustment bumpers and whre there is some bracing under the hood. Also find a spot where they will sit the most verticle. Once you decide where, transfer your local to the top side, tape the area so as not to rip apart the CF and double check, then drill. check out Stazi's car, I know he has pins. PM him for any other specifics. Good Luck.
#1122429 12/08/04 07:03 AM
H
H
GOOD NEWS!!!!!!!!!!
took me like 2 hours to figure out what was wrong but i got it. i took my grill out o see if i could figure it out and what it was the latch didn't go low enought for the hood to latch and the latch was to close to the front clip (frame) so what i did was dremeled maybe a half inch up on all three holes on the latch and then put a spacer behind the latch that i made out of 3 8th inch sheet metal. and then i put in behind the latch so it brought the latch out more. and what do you know it worked i was so happy that i didn;t have to put hood pins in my hood and ruin my whole look of a good hood. so if you need any advice i would be more then happpy to give it to you when you get your hood in.
the reason why i had to do that to my latch was cause the hook on my stock hood wasn;t as long as the hook on my CF hood.
#1122430 12/08/04 01:13 PM
Even with just the latch I would still highly recommend getting hood pins. Just the Latch could still make your hood wobble in high speed and very dangerous. Compare the weight of your heavy stock hood and this light and flexible CF hood!
-dan
98 CSVT 484/6535,18" MI Rims,Nitto NEO GEN Tires,Pioneer DEH-P7300,Custom Cougar CIA,CF Hood,McCULLOCH HID 6K,Custom painted red calipers,Flowmaster 40s mufflers,Drilled Slot rotors,K&N 9" air filter,Brullen HiFlo Y Pipe & CAT,Magnaflow Res
#1122431 12/10/04 01:46 PM
can you post pics of how you modded your latch, also if anyone can put up some pics to get a better visual.
~Alex
