My transmission slips kinda bad from 2nd to 3rd right now after I changed my transmission fluid. It also has a suddle 3rd to overdrive slip but it has had the 3rd to overdrive slip for 18k miles without a problem of it getting worse. Autozone says my egr valve is shot and I have a bad VSS I found a dissconnected wire that was touching the frame of the car but I reatched it but it may have been grounded out for awhile it is one of the 3 wires that goes to the VSS. I have 1995 ford contour 2.0 auto. The tranny slip is worse when its cold but settles down when it warms up.
1995 Ford Contour GL 2.0 zetec ATX hanging in there 1994 blue Ford probe SE
