Posts: 97 |
What would be the easiest way to remove the stock head unit? Also, will a replacement unit slide right in or is there some sort of "adapter" to make it fit tightly? Thanks in advance!
98 E0 SVT Frost Silver No mods...yet.
Posts: 1,075 |
You need a Ford radio removal tool...You can get one at most any car parts or car audio store...In a pinch you can use a wire hanger, but it's kinda hit and miss with those...Your new stereo should have a metal "frame", or "can" that goes around it. Bend the tabs up so that when you slide it into the dash they lock in behind the opening...this will make it a b*tch to get back out, so make sure you do everything correctly the first time! Good luck!
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 97 |
Well I've used a hangar, and gotten the stereo to come loose, but for some reason it wont slide out for me. I also understand I need a wiring harness that bypasses the stock amp, is that correct? Are their different models of harness's? Also, lets just say I dont want to do this myself, any idea what a stereo shop would charge?  Also, if your in the D/FW area and want to lend me a hand....I'll buy beer. Thanks again ya'll!
Posts: 2,848 |
THe radio removal toold are hit or miss as well. If you don't plan on using the stock HU ever again, like mine, you can carefully get a screwdriver between the sides of the radio and push on the clips to get it out. I had to do this as one side of my radio would not come out.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 86 |
call crutchfield, they have an entire kit: removal tools, harness and amp bypass harness....you'll get it in 2 days, w/ a ton of car stereo info....including instructions...save yourself a headache and order this from crutchfield...i just finished my installation this past weekend... and it was a snap....a nice clean installation....
99'Contour SVT #1766 of 2760 stock-for now, mods in the making pionner deh-4400 cd/xm head unit pioneer 4x6 component plates(front) pioneer 3-way 6x9 (back) (2)8" Boston Accoustic Rally Series subwoofers Alpine 3527 amplifier MTX RT-XO1A electronic crossover
Posts: 294 |
No need to get a tool - just put nails in a conner holes.
Regards, Kirill 98.5 Contour SE Silver Frost (powered by Duratec 2.5L) Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i \_ Blaupunkt ODx694
Posts: 86 |
yeah, you could but if you bend 'em...you could end up screwin' yourself and jamming the stock hu....if he has to order the bypass harness, why not just get the tools as well...it is like three bucks.....
