painting the doors and trunk will require them to "blend" the paint with the rest of the car. Otherwise it will not match. If the slight discoloration won't bother you, then probably $150 a piece. Blending will most likely require them to paint the side(s) of the car, and in that case probably closer to a grand total.
1999 Silver Frost SVT
#609 of 2760
