Okay.. Honestly, i've done this before. It's not that hard, but as long as you don't turn up your music that much, you won't be blowing fuses like crazy. Just get an AC/DC converter from 120V to 12V. Connect the remote, and power on the same line (or you could put an on/off switch for the remote, to turn it "on and off"), and make sure you have a fuse on the main power, and connect the ground. Then all you would need to do is connect everything else like a car, and your set..
