I honestly donâ??t wanna re-open a can of worms guys. To anyone that was offended by the last iteration of this post, I sincerely apologize. Further, I am not meaning to circumvent the lock on the other post. I just want your comments on the below email I got from my brother who is doing his PhD in engineering physics at Stanford (his PhD has nothing to do with fluid dynamics), I am merely giving you his background to gauge the relevance of his remarks.
He wrote:
â??The answer to your question isn't all that easy to come up with -- as the gas is compressible in general the flow behavior can be pretty complicated. However if we assume that the flow rate is always well below the sound velocity (though near a nozzle this isn't a great assumption), but the flow is still fast enough prevent significant heat transfer, then you can treat the gas as incompressible. In that case it is only the more restrictive of the two choke points that matters.
The turbulence induced by the converter mesh isn't all that relevant -- gas flow in channels is almost always turbulent.â?
Iâ??m guessing his assumption that the gas flow is fast enough is incorrect (I would think that it probably is not fast enough at all.) I donâ??t wanna get into a super technical discussion that is probably over my head but if anyone is interested, could they run an analysis to ascertain if the speed of the gas flow would result in practical heat transfer in a fully warmed up exhaust or if such transfer is negligible?
Thanks
