Posts: 51 |
Normally what is a good signal to noise ratio for an amp and what affect does it have on SQ? ~Brian
Posts: 1,075 |
if I recall correctly, the s/n ratio should be as high as possible...what it is, is the amp's ability to distinguish btwn. music signal from the source and dead signal (such as btwn. songs, pauses, etc.) A high s/n ratio eliminates the hiss in your speakers during silent parts of songs... If I'm wrong, somebody correct me...
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 1,032 |
That's correct. Higher is better. It means you've got more more of the original source signal than added noise/distortion.
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 51 |
Cool, thanks for the info
Posts: 1,444 |
what would be a good minimum s/n ratio to look for for sq purposes.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 1,032 |
I wouldn't go with anything less than 100.
