Posts: 1,085 |
Originally posted by GrandMasterKhan: The Zetec is 50lbs lighter
So.....now all us Zetecers can Super Size.......
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 367 |
50 lbs, thats all? I always assumed that we Zetecs were at least a couple hundred pounds lighter. It does seem to make sense now being that the V6 is only 1/2 liter larger in displacement.
However this is only the difference in engine weight. When you figure in all the extra support structure such as the larger subframe, thicker radiator, and v6 badges, that might creep it up there.
Posts: 6,910 |
Originally posted by DemonSVT: Originally posted by brapple: I always thought the zetec was a bit lighter and hense why it feels a little more nible then a duratec car and had a slightly better turning radius
Turning radius is controlled by the rack and steering stops.
The engine weights for either engine are very close.
my mistake then, but I could swear that between our 95's, one having the duratec and one a zetec my zetec could pull a slightly better, smaller radius u-turn, this of course being in the intersection on a side street by my house
- 95 Mystique LS - Zetec/5spd
Posts: 21,653 |
Originally posted by DESIGN: 50 lbs, thats all? I always assumed that we Zetecs were at least a couple hundred pounds lighter. It does seem to make sense now being that the V6 is only 1/2 liter larger in displacement. However this is only the difference in engine weight. When you figure in all the extra support structure such as the larger subframe, thicker radiator, and v6 badges, that might creep it up there.
Zetec=iron block Duratec=aluminum block Radiators=same I think except for svt v6 badges=very very heavy
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,975 |
I read one of those car review books and it said the zetec, since it takes up a smaller area transversely situated the R&P can turn farther, hence they said the V6 had a crappier turning radius.
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 9,602 |
Originally posted by Cris'pus: I read one of those car review books and it said the zetec, since it takes up a smaller area transversely situated the R&P can turn farther, hence they said the V6 had a crappier turning radius.
The only problem with that is the wheels can't turn "inside" the inner fender or liners.
The powertrain sits completely inside the engine bay so it's size would not make any difference.
The only difference listed in racks is SVT or non-SVT since the SVT has wider tires.
The SVT has slight sooner stops. Hence the SVT's lock to lock is slightly shorter and thus the turning radius is slightly larger. (miniscule actually)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,732 |
Originally posted by Booger: And probably highest likelyhood to roll over. I'd still drive one though.
true!
it makes a great beater though!
Russell
Oval Port 3L Nearly Done
Posts: 34 |
For a given model, the turning radius is set for the different trim levels by the stops, and the determining factor is the tire diameter. They take the widest tire package available for a given trim level, and all vehicles for said level will get the same width stop (rack limiter) no matter what wheel is actually selected for the vehicle.
The limiters can be removed and altered. Don't alter them so much that the tires will rub, or shops will give you a hard time installing tires.
