#1117599 11/30/04 12:27 AM
SVTBURG Offline OP
Would a hole in the gas tank cause the car not want to start easily and run really rough??
99 SVT tour 00 Mercury Sable (winter car) 03 600 RR
#1117600 11/30/04 02:36 AM
F
F
Where is the hole? If it is above the gas, your car might run rough. Does the check engine light go on? If it is below the gas it would just leak.
#1117601 11/30/04 03:26 AM
H
H
You would get a CEL for sure, for the EVAP system having a leak.
The EVAP system is tested for pressure holding I think everytime the car warms up, except when the gas is below 1/4 and above 3/4 because it cant get an accurate reading, also with Chrysler, if it is below -38F outside then the test isnt run either.
#1117602 12/02/04 12:47 AM
If the hole was on the bottom, then yes as all the gas would run out....
Otherwise, no.
Steve
#1117603 12/04/04 08:21 AM
SVTBURG Offline OP
The reason for the whole in the tank, is because of my swa bar. I have the aussie bar (which has no flex) and i went up an incline and it snapped( without my knowledge). Well after awhile it rubbed a whole in the gas tank. I cant put anything past a half of tank or else it would leak out. It does NOT throw a CEL however. Im just wondering if this is the problem im having with the major problem im having with the car.
