#1117357 11/29/04 05:48 PM
Hey Folks;
This is really getting on my nerves; I have a 98 contour with 147000 miles on it and Now its doing Wierd things.
1. When you start the Engine, CEL comes on and stays on.
2. When your giving it some on the interstate going up hill
(65mph) Boggs down makes a noticeable snapping sound,
I can feel it on the gas peddle and under the drivers
Seat.The CEL Blinks for up the hill then stops.
3. Ford dealership Plugs and wires and veryified that they are the correct ones.(dealership here wont touch it Had problems with them charging for thing they never done)
4. In town driving (under 40mph) hesatation when comming off the stop sign or light.
I really like my ride its a Ex Main State police car and was re done before i got it
please help its driving me crazy
#1117358 11/29/04 05:54 PM
Go to Autozone and have them pull the code(s) for the CEL
"Here's a mirror, see your stupid face!"
#1117359 11/29/04 06:02 PM
Good thing AZ is only down the street.... BTW I just crawled out from under it and the wires that connect into the exhaust (just as it comes from the Front of the motor)
are loose but connected.(from the Little silver thingy that goes into the exhaust pipe) What do they do or can i jump them or bypass them?
#1117360 11/29/04 06:08 PM
Sounds like you're describing your O2 sensors. Leave them alone for now. Get that CEL checked & do a search for the code. That will give you lots of info & a direction to work in. I'm guessing it's the pre-cats that are clogged, but the codes will tell us for sure.
#1117361 11/29/04 06:12 PM
new o2 sensors about 5 months ago done by vip
#1117362 11/29/04 06:39 PM
I was just responding to the previous post. The O2s are definately not a solution to your current problem. Get the codes & we'll troubleshoot from there...
#1117363 11/29/04 08:18 PM
Well after going to autozone and the bone head there said we dont do that (Get Engine Codes) After complaining to manager (the other dude did not know how) i got the following codes
136
141
304
I hope this helps
#1117364 11/30/04 01:19 AM
You have a 98.
Your codes should have been in the format PXXXX where XXXX is a four digit number (leading zeros are included...)
Steve
#1117365 11/30/04 01:36 AM
well add a 0 infrount of them then
#1117366 11/30/04 02:36 AM
You have a miss on cylinder four. Recheck the plug and wire.
Is this a Zetec?
Bank 1 downstream O2 has a problem, probably in the wiring. If this is a Zetec you may also have a plugged cat. Suggest you check exhaust backpressure.
