Posts: 97 |
hi guys, the first time i turn on my car everyday it idles for about 10 seconds and then it just dies out...ive beeen wondering what could be the cause of this, i have replaced spark plugs, and cleaned the MAF sensor and it acts the same. It only happens the first time it starts in the day..whether it is in the morning or after noon. AFter wards it turns on fine and doesnt do it.
Also my idle is about 1200 at park, then when the car gets warm it drops to about 900-800. Then when i turn my AC on it goes down to about 500-300 and the car begins to shake. Drives fine, but at a traffic light it just shakes and vibrates..kind of annoying. any one else have this problem?
just wondering what u guys think of this, i know some one out there can help, thanks in advance..any input would help
~ Fastest 95 Gl Atx Zetec in Long Beach ~
"Who would ever spend their money on a car that can't get 200hp N/A"
~ Slowest High Performance Car and Proud of it! ~
Posts: 21,653 |
Idle Air Control valve ,,,, pcv valve, fuel filter, dirty injectors, etc.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,725 |
Sounds like you own an exact copy of my car.
With the dying same thing here, there are two main things it can be, dirty IAC valve, or there is a TSB for dying after 8 hour soak a revised MAF is installed to fix it.
What I do so I dont have to start it twice and put more wear on the starter is, hold the gas pedal at like 1500 for like 5 seconds, the it drops down to 1000, then I hit it slighty to like 1500 and it wont die. Problem is the IAC valve is gonna cost you $189 from Ford, the MAF is $140 I think, so if your just going to guess hopefully you make a lucky one.
Secondly with my A/C or defrost on it to shakes terribly, also my idle goes up and down 500-700, so annoying. Let me know if you find a fix for it.
Posts: 610 |
IAC or the wires from there to your pcm, thats what it was for mine. but that sounds quite common
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
Posts: 137 |
where is your IAC and how do you check it or make it work good or whatever the word for it is?! sounds like a replica of my car too
WTB:
Andy's Auto Sport front bumper only...
a chip for my 98se
Posts: 862 |
Can you just take the IAC valve out and clean it? I have done that on other cars.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 82 |
Hey, this is a good thread. Don't let it die (like my car)!
My 95 Contour also has a bad, rough up and down idle and sometimes kills when cold. But since I drive on the highway mostly I have lived with it.
I replaced the IAC (Idle Air Control?) valve on my '89 Ford Tempo to fix a bad idle and it worked, but that only cost $50.
The Contour IAC is $189?
Wow!
1995 Contour GL "GEX"
2.0 Liter 4-banger
ATX
162,500 miles
Stock except for two '89 Tempo wheel covers & two VERY COOL cosmic looking '76 Toyota Corona wheel cover
Full size spare
No rust
Green
Purchase price: $500
Posts: 750 |
Originally posted by JohnHoward: The Contour IAC is $189?
$66.99 at autozone. It's a hell of a project to replace it. Just cleaning it might help, I recommend replacing it though since you don't want to work on it again anytime soon...
T.
Posts: 1,085 |
Wow!
You in the great white north?
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 2,725 |
Originally posted by tiv: Originally posted by JohnHoward: The Contour IAC is $189?
T.
Yes, it cost about 2.5 times less than Ford, we can assume it will last about 2.5 times less as well. Autozone parts = junk
