There was a post about a week or so ago where the poster was looking for the distance from the crankshaft flywheel face to the rear of the cylinder block. (Duratec engine). For some reason, the post is now gone as my link doesn't work and it can't be found by searches.
For anyone still interesed, the nominal distance is 4.6mm. Looking at the tolerance stack up, it could vary about 0.45mm but in reality it should be fairly close to 4.6mm. Hopefully this helps someone.
ill let the guy know! ( the post was deleted cause the mods did not like it)
thanks
Brad
98' Red E0 Contour SVT - Project SVT Tour' Pioneer Touch Screen Navigation / DVD, Infinity Speakers Borla Stainless Cat-Back, AEM True CAI, High Flow Y-Pipe 3L Hybrid w/ 3L Valves, Window Automation, Torsen LSD
Thank you very much Procyon.
-mobiuslogic
