Posts: 127 |
Well right now i have a dei 600d that is wired out of one of the two speaker terminals on the amp. It runs into one outlet of the box which has two eclipse four ohm 86120 subs. I had them in a q-logic box with lots of air space but i just recently put them into a much smaller enclosure. its a box i had made for two infinity perfect 12.1's. Is there any better way to run this setup?? Any help would be great...thanks.
2000 Svt kkm intake w/heat shield, custom MAF,under-drive pulleys,braided brake hoses,carbon fiber brake pads,painted calibers,17x7 borbet t's with g-force tires,bat euro struts,eibach pro-kit,custom burned superchip,sho offroad y-pipe, bassani exhaust with high flow cat,formula one tint,kenwood excelon cd/mp3,mb quart compents w/mtx amp,b & m short shifter, carbon fiber pedals,hyper-bright bulbs,painted oval ring and many mods to come.
Posts: 918 |
Edit: The 600D is a class D mono amp. www.directed.com says it's one ohm stable. This may help you out: One ohm wiring Assuming the subs are DVC, you can wire the subs parallel(see pic- 4 coils, 1 ohm load) to get a one ohm load. If you already have it wired this way, congrats! You are getting the most power from your amp.
************************* 2000 SE Sport V6 Deep Navy CC Metallic My 2G Sport *************************
Posts: 127 |
well actually i guess mine now are wired in a series. I do not entirely understand that diagrahm...4 outlets per sub. Maybe i am missing something?? Any clarifaction would help..thanks.
Posts: 918 |
I went to Eclipse's website, and it showed the 86120 offered in a Dual Voice Coil. Are yours? I assumed those are the ones you have. If your subs are single voice coil, this would be your best bet: SVC wiring 4 outlets meaning: Two sets of voice coils, one set + and -, and the other + and -, per sub.
Posts: 127 |
thanks for the help... they happen to be signal voice coils. Not too bad considering i got them both and a box for 300 but not the greatest either. I am trying to save up money to replace the two infinity perfect 12.1's that i managed to blow. I am hoping for some alumapros or planet audio subs in the near future but until then i gots to deal. Thanks for the help.
