I am replacing my front brakes (99 SVT built on Oct 28 1998) and when I took the rotor off it is the 278 mm from the E0 run but the pads do not match it. they are the thinner pad from the later calipers
Is it common for the larger (earlier production type) rotor to be installed with the caliper and pads from the later runs? Should I just go replace the pads with the right size and return the ones I bought?
Of course the best thing is I wanted to get this done on my day off, which means most auto parts are closed
