Posts: 111 |
Flashes intermittantly only during acceleration and cornering. I don't feel any grabbing or anything to suggest the park brake is sticking, so I'm assuming its a weak switch thats making during said conditions. Anyone else ever run into this or know where the brake switch is? Thanks
98 E0 #4100 18's n stuff
06 Mazda6s Sport Wagon
89 Thunderbird SC
Posts: 768 |
low fluid
Posts: 111 |
I never thought that light was multi-function. It comes on to indicate parking brake is set only, right?
89 Thunderbird SC
Posts: 2,725 |
Originally posted by csvt_33: I never thought that light was multi-function. It comes on to indicate parking brake is set only, right?
No 3 three reasons only, well four.
parking brake set low fluid in master cylinder a brake line snapped grounding that thing on the master cylinder, completed circuit and lighted the dash light
of course a serious eletrical problem could cause it as well
Posts: 111 |
idiot now heads to garage to check fluid levels...
89 Thunderbird SC
Posts: 2,725 |
Originally posted by csvt_33: idiot now heads to garage to check fluid levels...
Remember DONT open the master cylinder unless you want to flush the fluid. Brake fluid cant be exposed to air.
Posts: 111 |
Well whaddya' know. Found sensor, found fluid only 'bout 1/4" above min. line. Thanks fellas!!!
89 Thunderbird SC
Posts: 1,788 |
Now go figure out WHY the fluid level was low.
Most often it is due to severely worn pads (or shoes). It can also be due to a leak.
Only adding fluid can cause a false sense of security.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 111 |
Thanks SHO. Makes sense. I know I'm due for pads n rotors, its been awhile, but stopping power is still so good that it's easy to forget.
89 Thunderbird SC
