Posts: 71 |
Where is the neutral safety switch located on an automatic V6?
1996 Contour LX----Fully Loaded Sony Xplod 650X 52Wx4 HU Pioneer TS-A6865 in doors Goodyear Eagle HP Tires All Around Hanging Black Dice Bocsh+2 DoublePlatnium Spark Plugs Red Spark Plug Wires EBC Greenstuff Brakes EBC Sport Groved Rotors
Posts: 1,861 |
It's part of the MLPS (manual lever position sensor). It is on the trans where the shift cable attaches. Top side of trans under air intake tube.
Jim Johnson 98 SVT
Posts: 71 |
Posts: 1,559 |
If your talking about the solinoid switch that keeps the car from shifting into gear without the brake depressed, then it's on the shifter mechanism under the consol. You have to remove the consol to replace it. The consol is four screws in the front, and two in the base of the arm rest. It takes about 30 minutes to get it out if you've doen it before abotu an hour if you haven't.
Posts: 304 |
The neutral safety switch is the device that keeps you from starting the engine when the transmission's in gear and is part of the MLPS as Big Jim stated.
Karl
*** It's all about consistency! ***
98 SVT Contour 86 Ranger GT 69 Fiat 850 Sport Spider 67 Formula-S Barracuda
Posts: 71 |
my reverce lights don't work and i think that is the culprit
Posts: 304 |
Quote from horseydug from similar post last year:
For the atx the back-ups are controlled via the TR (transmission range) sensor which is located in the engine compartment. This device also controls the starter interlock.
Karl
Posts: 1,861 |
The transmission range sensor and the manual lever position switch are two names for the same thing.
Jim Johnson 98 SVT
