Yes, I've searched numerous places.
My '95 GL didn't come with keyless entry (so it doesn't have the wiring harness connections - I've already checked). I don't like any of the aftermarket keyless entry systems; I'd like to retrofit a Ford keyless entry into my car.
Getting the keyless entry module and transmitters isn't very hard (eBay). There are many sources of factory wiring harness info; hooking it up should be fairly straightforward.
But all of the keyless entry wiring info presumes you already have a harness with keyless entry: They supply wire colors, not pin numbers/locations on the keyless entry module (receiver box). None of the keyless modules I've seen for sale come with a connector (and the all-important color-coded wires). By the time I talk to the seller, they don't have the car (and wiring harness) anymore.
So... Short of spending time with wire cutters in a junkyard, is there a way to get wiring pinouts of the keyless entry module?
Thanks!
Phil
1995 Contour GL V6 ATX T/C 1986 Mustang GT 5.0 2000 Windstar LX
I looked a little bit thru the service cd, couldn't find the wiring for the keyless... maybe I was looking wrong?
There should be a manual somewhere that shows it, maybe going to your local Ford dealer's service dept. and seein if they know where ya can find it...
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
Yes, you're running into the same thing I am.
Yes, I'm sure there's something out that that documents this - but it doesn't tend to show up in the usual automotive electrical locations.
N
N
I found the electrical diagram for the keyless entry.
And i have the connectors view, both male and female.
Connector 227
Connector 230
And connector 221, probably the most usefull
Check on the diagram, where you see c221, c230, c227 that is the connector number.
I'm not sure but connector 221 might the one that will help you.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Nic ContourSE99 -
Thanks for the info!
What year is this info for? I know there were some changes over the years.
That's just what I was looking for.
Phil
Nic ContourSE99 -
Hmmm - Now that I've stared at the diagram for awhile, I've still got some research to do.
It's interesting that the RKE connector diagram includes trunk decklid release, horn and dome light outputs - but not door lock/unlock outputs.
More to learn...
Phil
N
N
phil:
Nic ContourSE99 -
Phil
This is for a 99. But i can have it for any year.
Nic.
Nic -
Hmmm - I'd be curious to see the pinouts for a stock '95.
Thanks!
Phil
N
N
phil:
Nic -
Thanks!
Phil
I don't have the info for a 95, i've checked fpr 96 and it's the same thing.
Nic.
Nic -
Thanks!
Phil
