Posts: 22 |
i took the lug nuts off my rear tire to check my back brakes and i am not able to remove the rear tire. am i missing something here? i see a flat meatal piece in the center but not sure how and if this is suppose to come off?
i've tried t kick it punch it no luck wont budge.
Posts: 319 |
if the lugs are off...just jar it a little with your fist...or your foot. sometimes the rims are just stuck on a little. just make sure the car is jacked properly when you do the banging.
Posts: 22 |
i still cant remove the damn wheel. it wont budge. is there something im missing? the lug nuts are all off. it just wont move
Posts: 313 |
Is it a steel wheel or an alloy? Some rust may have formed, and isn't allowing it to release.
If all 4 lugs are off, hit it harder (a few really firm kicks to the tire sidewall should do it; check that jack first!).
You could also try some penetrating oil by each lug, but don't let it get on a braking surface or pad/shoe.
If there's enough rust to hold the wheel on, I hope you don't need much brake work; probably more rust jamming things together in there.
1995 Contour GL V6 ATX T/C
1986 Mustang GT 5.0
2000 Windstar LX
Posts: 72 |
You could also try this method if all else fails.
Put all the lugs back on hand tight. Lower the jack, and slowly drive the car back and forth a few times to break it free.
99 SE V6
Silver Frost
201,592 Miles (Still Running Well)
Posts: 6,791 |
Ahh yes i remember when this happened to me. NOTHING and i mean nothing would get those wheels off!!! I finally got success when i hand tightened the lug nuts and then dropped the jack and it broke the tires loose!
Posts: 759 |
Hah, just try removing your rotors to have them resurfaced...I had to take a propane blow torch (minding the brake lines) and head that sucker up until the rust heated away!
E0 #4384 of 6535
Born Jan. 9 1998
My SVT from the ashes
147,466 miles, purchased Nov. 2002 @ 76,559 miles
Posts: 465 |
Use a plastic mallet and bang the crap out of it from behind as the wheel is rotating. The plastic won't harm your rims or anything, and the wheel will eventually pop off. I think the vibration of repeatedly hitting the wheel as its moving helps a lot. Works for me at least.
Old car: '98 SVT T-Red
K&N air filter; Ford Focus RS shift knob. Off to be auctioned off somewhere.
New car: 2003 Honda Accord DX Sedan, 5-speed.
Posts: 1,017 |
damn people, don't you ever rotate your tires? they shouldn't be fused on by rust THAT badly if you take them off at least every few months. maintenance on my car seems to have me taking the tires off every so often for one reason or another, but geez, I can't imagine how long that took to make a blowtorch necessary.
1995 SE
2.5L V6/MTX
187k
Posts: 1,505 |
get a dead blow and just hit the tire do not hit the rim
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
