#1109691 11/18/04 10:30 PM
Ok hears the deal I have a 99CSVT with 84k and the clutch has never been replaced. What is happening other than a hunting idle which is another story....is that when sitting in traffic or at a light with the clutch depressed and the car in gear if you rev the motor you can feel a slight lurch as if the clutch was partially released. The clutch doesnt slip when in gear. It feels as if the linkages need adjusting is this common and how would I go about this if it is in fact the problem. Any help would be appreciated...
Thanks
#1109692 11/18/04 11:06 PM
When you rev the engine the clutch is designed to grab harder. It sounds like there is not enough freeplay, which is the reverse of what happens with a worn clutch.
I would recommend bleeding the clutch first.
#1109693 11/18/04 11:13 PM
Mine was doing that before I replaced the clutch. If I touched the gas at all I would feel a little pull in the car. It got pretty annoying. I also had problems with tight shifting and the clutch slipping.
I had none of these problems after the replacement, but dont know for sure if you need to do the same. Might just need an adjustment.
