Posts: 379 |
I found this interesting clock in a thrift store. It's clearly made to be mounted in the dashboard of some kind of vehicle. The markings appear to be in Russian. Can anyone tell me what they mean? The character hidden behind the hands of the smaller clock face at the top is the same pi-like character that appears between the O and the E shortly afterward.
Hyster E60XM-33
1996 Mercury Mystique GS, Zetec, ATX
To email me, remove the string HatesSpam from this address:BobHatesSpam@Blaylock.to
Posts: 2,039 |
Top dial is barometer and bottom dial is sec for seconds.
Or if I had to take a guess...
Seriously, not sure about the top dial.
-J
'98 4Runner
Posts: 2,039 |
Chit, doubt it's a barometer, wouldn't make sense.
'98 4Runner
Posts: 379 |
Originally posted by JVT: Top dial is barometer?
Nope. It's definitely not a barometer. The the state that the clock is in now, the upper dial doesn't run. If I push the red button/knob on the left, the white sqaure in the lower part of the upper dial turns red, and the upper dial begins running like a regular clock, with a minute hand and an hour hand (no second hand). If I press it again, it stops, and the square is half red, half white. If I press it again, the square goes white again, and both upper-dial hands reset to zero.
Originally posted by JVT: ?and bottom dial is sec for seconds.
Nope. It measures minutes ?? thirty minutes to go around the dial. There doesn't appear to be any way to ??set? this dial. As for remaining controls: Red knob/button on left:- Pushing it affects the upper dial as described above.
- Turning it counterclockwise winds the clock. (This is a stone-age spring-driven clock.)
- Pulling it, and then turning, sets main clock dial, just as the winding knob does on most stone-age watches.
Knob on right:- Turn it clockwise, and the main clock stops.
- Turn it counterclockwise, and the main clock starts running again.
- Press it, and the main clock stops; press it again, and the second hand goes to zero; press it a third time, and the main clock begins running again.
Hyster E60XM-33
Posts: 3,290 |
In Soviet Russia, clock sets YOU! [/Family Guy]
E0 #36
'95 Ranger
'82 Honda CX500
Posts: 2,132 |
I think it is used for aircraft altitude but that is just a guess.
Posts: 1,677 |
I work with a Russian, I will ask him when I get to work.
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Wild guess!
Month!
Day!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 1,074 |
Originally posted by Andy W.: Wild guess!
Month!
Day!
-Andy
Thats exactly what i was thinking. My friend speaks russian so I will ask him and get back to you.
Brett
The man thinks its best for everyones safty if i dont drive for 6 months
'95 Moonlight Blue Contour (ITS ALIVE AGAIN!)
MODS:
Knauberized,Reverse Indiglo Gauges,LED's,AEM Intake,Rust holes for more power!
Posts: 768 |
amateures, sit down before you hurt yourself... top dial: "time of flight" -- it just measures hours. bottom dial is seconds. the rest is a regular clock. the gray print in the middle of the main dial says 2 - days
