#1108048 11/17/04 12:44 AM
I got a P0402 and a p1405 serched . cleaned the egr valve passage witch was packed with black crud and cleaned egr valve. reset computer now i get p0402 no p1405 so should i replace, egr valve or dpfe?
car idle's funny pulses up and down
also put on euro struts and eibach springs do i need a allinment?
1998 contour svt 3L
#1108049 11/17/04 12:49 AM
Pull the vacuum line to the egr valve and see if the idle smooths out. if it does, the egr vacuum regulator is probably messed up. Also, the egr valve may be stuck partially open. You can check this by feeling the egr pipe after a short idle time (about a minute). Be careful! it may be very hot. I would expect that the dpfe sensor is bad, though.
#1108050 11/17/04 01:29 AM
H
H
Hey Greg got a question.
The car (96 Zetec) like most Tours has a rough idle, so what your saying if I let it sit in drive and then pull the vacuum line and it smoothes out the EGR regulator is bad?
#1108051 11/17/04 01:46 AM
P0402 is related to the DPFE sensor, exsessive egr flow at idle, I had this issue last summer and there is a good thread on it if you search for it
but do check the egr valve first, when you apply vacuum and the idle stumbles the valve is fine so it will be the DPFE sensor
#1108052 11/17/04 01:22 PM
How Do i apply vac to it ?
#1108053 11/17/04 01:52 PM
"Personal Facial Vacuum source" - Pretend it's a milkshake....
#1108054 11/17/04 02:33 PM
HAHA!! I remember that!
I just pulled a lenghth of EGR vac hose off an old Mercury V-8. I can plug it into anything & apply vac as needed. Pick up a couple feet of vac hose from your local auto parts store for $2 or less and use that.
