#1105585 11/14/04 04:08 PM
hypothetically....
96 or under contour..... 1200 ish
small block chevy .... 2000 ish
turbo 350 tranny .... 500 ish
custom driveshaft .... 250 ish
ford 9 inch rear end ... 800 ish
mig welder to make it work 250 ish
these prices are a bit high and would give you a decent setup. althoug im forgetting prices for a custom leaf spring and traction bar setup for the rwd setup. i think this is quite feasable for less than what i just made up from the top of my head. but as far as fitting a sm block 350 i know it would fit as ive measured my friend sm block in his s10. 350 focus are getting popular to and there is one that was done for less than 5 grand. the focus swap is a bit more appealing for just the thought of a focus fliping out and killing a cobra for no reason. just a thought. i think a 302 would be even cheaper.
blah
#1105586 11/14/04 05:02 PM
I'd hit it!
That sounds fine and dandy til it becomes time to actually start fabricating EVERYTHING. To most people, it SOUNDS feasable... but really, it just isn't worth the cost, trouble, headaches, and unknown territory you face when doing this. You are talking about moving and redoing pretty much EVERYTHING under the car, let alone, cutting the axle down to fit, changing out the front suspension (cause there's no way that even a 302 will fit with the stock setup)gas tank would need to be moved, and god knows about the tranny, you'd have to cut out an opening in the floor under the cosnole to fit that sucker up and in the car so it wasn't draggin on the ground. You'd have to adapt some kinda console to cover the large behemith tranny that is now sticking through the floor past the CD player (exagerating a bit), and you know we's gotta have our CD's??!! And besides, even if you did have this set up and built.... ya know how much that beast will weigh? Reinforcement, reinforcement, reinforcement. Usually people don't repsond liek this.. it is usually someone saying... "Why, just put a 3L with a quaife and some bolt on's.... that'd be just as good." But I feel ya broth er, nothing would be more cool to roll up next to a mustang, camaro, GTO, or what have you, and not only sound like your cars pissed off like it didn't get no nookie last night, it also beats the piss out of them all aswell. Makes me droll thinking about it. But, logic comes first in the real world.
Oh, and I'm not out to be the burster of boubles, if you got the skills, by all means, make this a reality and make every CEG'er envy you.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
#1105587 11/14/04 08:05 PM
E
E
It would probably be considerably cheaper, and probably easier to find a wrecked Mustang. Split the pinch welds and take the body off. Do the same to the Contour. Mod the Mustang's floorpan as needed and weld it under the Contour. That would get the fuel tank, rear suspension, trans tunnel, etc out of the way. Adapt the Mustang's front subframe to fit and then work the bugs out of the front suspension.
The one probably I see with a straight axle under the rear of our cars is clearance. You would have to lift the floor a lot to allow the axle to have its movement.
If you want a V8, supposedly the Jag 4.0 will fit. Granted you would still be FWD but from measurements, it will fit.
· Jon Miconi · Coming Soon! · 01 Cougar · 98 V70R
#1105588 11/14/04 10:29 PM
don't know which one it is but there is already a jag that looks like its a knock off of the contour that has awd and a v8 i think
1996 zetec atx 19.3381 at 71.51 mph 1/4 mile click me for an interesting sitea wbsite you should check outjoined the 100k+ club 5/21/06
#1105589 11/14/04 11:53 PM
9
yeah the x-type,yes awd,no v8,just 195 hp 2.5,and 223 3.0L, mondeo rip off
#1105590 11/15/04 02:10 PM
Y
Y
Mark
#1105591 11/15/04 02:43 PM
Originally posted by dallasb84:
hypothetically....
A chevy motor in a Contour
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#1105592 11/15/04 03:20 PM
hypothetically....
Cost to actually fabricate this to work. PRICELESS
#1105593 11/15/04 03:26 PM
hypothetically....
priceless=lots and lots of $$$$$
1996 MM Zetec, ATX 192000 kms...not dead, but I'm not fixing it White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
#1105594 11/15/04 03:46 PM
Originally posted by Y2KSVT:
Mark
How long it take you to do that...hahah
2005 Nissan Sentra Spec V
