Posts: 4,016 |
It doesn't happen all the time, but my headlights have dimmed on me a couple times. Nothing else dims really, just the headlights. Once, the instrument panel dimmed and some of the lights lit up. It only occurs for a few seconds, then powers back up. My wipers sometimes go outta wack to. What gives? Am I having electrical issues or do I need a new alternator? I just had a new alternator installed about 20k ago.
2006 Mazdaspeed6
1997 Yamaha YZF1000R Thunderace
1996 Volvo 850-R
Posts: 392 |
When does it happen? In which conditions? Did your battery lamp indicator light on?
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 4,016 |
It happend the other day and it was dry and cool. The wipers happen when it rains heavy. I didn't notice a battery lamp indicator.
2006 Mazdaspeed6
1996 Volvo 850-R
Posts: 3,944 |
If the dimming happens during acceleration, then it is your alternator. do some searches and you will find a boat load of info on that subject.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 4,016 |
Originally posted by unisys12: If the dimming happens during acceleration, then it is your alternator.
Yeah, I did search and it did dim under acceleration, however, like I said, I JUST had a brand new alternator about 20k ago damn Ford parts!
2006 Mazdaspeed6
1996 Volvo 850-R
Posts: 6,791 |
Recently in the moring it has been in the upper 20's, lower 30's around here. Upon start up the battery indicator light will come on. I hate when there are any lights on my instrument panel. So i will pull over turn off the car and start her back up to discover its gone. Cold cold weather have anything to do with this?
Posts: 2 |
Mine dim when I hit the brakes hard (ABS working?), and the engine wants to quit, even if I have the clutch pressed in. Is this normal? Any suggestions? Dan
Posts: 7,117 |
I also recently had electrical issues. I changed the alternator - which had totally failed. I then had the battery cables replaced. That seemed to solve all the remaining problems.
Posts: 6,791 |
That is the second time i have heard to replace the battery cables. I'm going to give it a shot... any advice. It sounds easy but i dont know much when it comes to mechanics!!! What size wire should i upgrade to and where to get it?? Thanks for the help
Posts: 446 |
The only time my lights dim, and it's not a huge dim, is when I operate my windows. It dims all my lights (headlights, interior, etc.).
