#1101512 11/10/04 01:57 AM
After cleaning my EGR Valve Saturday, I finally found time to go fill up the tank. Goods news is no engine light, but thats not the point of my message. Since gas where I live dropped around 8 cents, I put the 93 octane or "super" in my tank this time. Did seem to notice a small difference in the motor. It sounds like it is running smoother. So I was wondering, what does everyone else put in their tank? cause the book says to use 89 octane or the medium grade.
#1101513 11/10/04 02:06 AM
I would think that if you dont have a CR of 10:1 or higher or FI you really dont need it. 87 would be sufficiant.
-tropictour
2000 Contour SVT Tropic Green SHO Shop CAI Bassani 1999 Contour SE BAT Kit
#1101514 11/10/04 04:06 AM
you really need to watch out when a general compression ratio is placed for fuel octane recomendations. there is really no way that you could run 87 in a car from the 60s with 10-1 and not get a knock factory. for most newer cars even ones like the csvt that have high compression ratios you can run 87...but, it is definitly not recomended. the computer can adjust enough in most cases things such as timing to deal with the fuel. however the car will then be WAY down on power and will not run right. bc of the things adjusted by the computer doing this can actually increase chances of overheating and not all knocking can be corrected. so in other words if you want your car to last stick with the manufacturers rating.
99 csvt 68 cuda fastback 340 00 gp gtp (wife) 01 gs500
#1101515 11/10/04 04:07 AM
-tropictour
It's not even the CR but the timing curve.
Unless you have a chip or an SVT the 87 works the best.
Sometimes as engines get older and get nasty build up they require you to increase the octane but you are not gaining any more power just stopping detonation. Actually you are "technically" losing power from shorter burn times albeit a miniscule amount.
#1101516 11/10/04 07:27 AM
N
N
To answer the question of what do i use, Shell VPower and only shell vpower. It's the only gas that keeps my CEL from coming on. Then again, I'm quite sure one of my pre cats is going and this seems to be just a band-aid.
Shawn Clone Jezabel- 1999 SE Sport V6 MTX- Severly wounded, comatose Silver frost/Black Exterior-Midnight Blue Interior The Firecracker- 1995 Mystique LS V6 MTX stock and backfiring like a rifle shot I have 3 loves, my God, Brittany, and my Car.
#1101517 11/10/04 07:20 PM
I'm using the VPower in my car and its gained a little pep since then. I'm guessing it cleaned out some of the gunk for me. The car was a little doggy feeling compared to the 95 Escort GT I had before it but feels about the same now.
2000 SE Sport 2.5L MTX Harvest Gold Stock except for K&N RU-3690
#1101518 11/11/04 10:03 PM
I put in 93 everytime, unless they have higher(not to often)..... whats a couple of cents per gallon, It's just gonna end up in the ashtray anyway.
Keith P. Killed in action-4/27/06 '99 CSVT #2369/2760-7/28/99 New Recruit- 1998 EO CSVT # soon to come Black 106,xxx
#1101519 11/12/04 04:08 AM
0
I've run 93 octane since i bought my car back in 02'. If you like how the 93 octane makes the car run your should try a couple of gallons of 100 octane sure its $3.00 a gallon but i'm paying $2.10-2.25 a gallon for the 93. sucks that 104 octane is $6.00 a gallon at the track .
I'll tell you this it will make a big improvement over 4K rpms but it sure does burn a hole hell of a lot quicker.
-2000 csvt silver frost #1619 -magnaflow 14415 -optimized T/B & y-pipe -superchips xgt1 -75mm proflow maf -K&N RU-3530 -fsvt smart pump # 354Z-9H307-BC -spec stage one, LSD -low-tek,a/f,oil press.,volts -B&M short shifter -17" konig gt-r
#1101520 11/12/04 07:52 AM
Actually higher octane fuel burns slower. Slowing down the burn is how it reduces engine ping.
#1101521 11/12/04 05:34 PM
N
N
From what I remember, higher octane fuel has more of a controlled burn, where low octane is more akin to an explosion, with no real control of the flamefront or anything.
