I replaced both my speakers yesterday, so let me give some advice.
The sail panel has a plug with a screw behind it. Both of mine were near impossible to remove. I used double sided tape, and even superglued a wooden peg to it to pull it out. One came off in this way, and the other didn't. Finally I carefully drilled through it and now need a new plug. So be warned.
Also, I don't have power door locks or windows (so your's may be different), but the plastic cup that sits behind the door pull on a '95 is very thin and easy to break.
Another thing to watch out for is the bulb on the lower corner lights. The wire can be short, so if you pull off the door panel you'll break the wires to the bulb housing. So remove the door screws and then pry that corner off and get your fingers behind the bulb and twist and pull it out.
