#1098935 11/07/04 02:20 AM
My head gasket blew this morning. I opened up the oil filler cap and it was all foamy and there was antifreeze and steam everythere. I havent turned it on since and had the car towed home. Is my motor trashed? Is it a hard job to change? Is it worth fixing, or would it be more smarter to put an used engine/trans in it? The car itself is in mint condition and I love it. Im sad. Since i have no idea what to do I am just letting it sit im my driveway untill I find out and in the meantime i am driving a 88 Mercury Tracer to get around in. It gets me from point A to point B, just no where near as comfortable, luxurious, or as nice as my tour did
My Contour is a 96, 4cyl auto, 159,000mi
#1098936 11/07/04 02:44 AM
I did my head gasket! Rather easy if you got time, and tools
Ill break it down for you
-Remove Intake air cleaner
-Remove valve cover
-Remove side upper engine mount
-Remove serpentine belt
-Remove the timing belt covers (also will have to remove the water pump pulley)
-Remove Exaust manifold shield, and spray PB Blaster rust penetration stuff on all the exaust manifold studs and bolts.
-Remove exaust manifold when you get the nuts loosened
-Unbolt intake manifold
-Begin removing camshafts after you get timing belt off
-Remove Cylinder Head
I may have skipped some things, it is a big pain in the ass if you dont know what you are doing, and/or you dont organize.
Label everything! (Intake bolts, Cam bearingcap #, etc)
Also torque everything down
I suggest buy the $16 Haynes manual at autozone for the Contour/Mystique
I might have a repair manual i can get in PDF format on removing cylinder head
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
#1098937 11/07/04 03:02 AM
Dude.. that sounds like a lot of work.
#1098938 11/07/04 06:05 AM
Took me a week to get off (Was during weekday, I had school, and then work on fridays)
Got it reassembled in 2 days because i worked on the weekend on it straightfoward
#1098939 11/07/04 08:34 AM
did yours blow completely before you changed it? was there antifreeze in the engine? I opened the oil filler plug and it was full of foamy antifreeze/oil mixture as well as the antifreeze tank. I shut if off soon after i realized what happened, hopefully soon enough.... In talking with some people i know, im scared that the head may be warpred? how can I tell? Will my motor be ok after i change the gasket even though antifreeze leaked into it all over the place
thank you for the info above......
#1098940 11/07/04 08:40 AM
Contourkev- is your Contour Green? If so it is a twin of mine. I checked out your site. I have a front end cover too. Mine has the stock aluminum 15' rims though.
#1098941 11/07/04 08:56 AM
Dark purple
