#1095408 11/03/04 03:30 PM
i want to take some aftermarket wheels off of another car and put them on a 98 contour but im not shure if they would fit...the car that im taking the rims off of has a bolt bolt patrern of 4x100 ,i know that the tour has a bolt pattern of 4x108,would these other rims fit the tour or not???
thanks for the help
nope. you need a 4x108.
Check if the rim has 2 sets of patterns drilled into it, the 2nd might fit.
hey CHF_Slapaho can you give me a btter idea about what itis you are talking about???
some wheels come "double drilled" with two different patterns on one wheel, and in my experience 4x100, and 4x108 are comonly paired.
this means ther are 8 holes, 4 in a 100 pattern, and 4 in a 108 pattern, if these wheels also have a 108 patern, you should be able to use them, but check the offset as it may cause other problems.
ya these rims have 8 holes so does this mean they would fit on a tour???
if the second set of holes is 4x108
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
F
F
Only way your gonna know is to swap one of these wheels onto the Contour.
Try removing one of these wheels, the offset is commonly stamped on the back side of the wheel. If its correct and lug holes line up, you can swap.
Report back with the offset and size wheel.
I
I
most likely going to be 4x100 and 4x114.3(?) I think thats the other common offset.
H
H
what wheel is it. research the wheel and see if its even available in 4x108
Moderated by  1314_dup1
