Posts: 27 |
i am looking into gitting a 98 tour se v6 5-speed in a couple of months and i will have some $ to drop into it...the reason for this post is to get everyones input on my own thouights..i was going to get the svt body kit but after seeing how expensive the full kit is i have decided to go more on the performance side of it.. this is my idea engine: -upgraded plug wires ($50) -dual mode dampner ($50) -sho shop baffel ($129) -custom exaust system ($125 for mufflers only,have a friend who can make custom pipes for me) -cold air intake (i currently have many bends for a cai ,price is $0 on this ) total $354 suspension: -coil over kit ($419) -------------------- other items thinking about upgraded shocks/struts superchips ecu upgrade -------------------- so you guys see were im going with this,please post your thouights and or ideas.
thanks
Posts: 9,872 |
Originally posted by jmsmathis: suspension: -coil over kit ($419)
what kinda coil-over kit you looking at??
Posts: 1,899 |
what exactly does a "DMD" do? does it give you any gains?
Posts: 7,025 |
Originally posted by 99_SE: what exactly does a "DMD" do? does it give you any gains?
its a crank dampener. No, it will no give hp gains. It may actually create a loss in hp.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,899 |
from what i gathered from the search feature, it allows the engine to rev up quicker and therefor make the engine reach max power faster... is that right?
Posts: 27 |
the coilovers i was refering to were the Ground Control Coilover Kit.............what do you guys think???...by the way i already have 17" wheels to go onto it as well...???
Posts: 6,700 |
Do what you said your going to do already.. and give me your change! Haha... You'd have some nice pocket change left, maybe do something aestetical or dress up the audio a bit. You could easily put in a good system for 5-600 bucks. Or, go for a nice set of corbeau's. Truthfully. I'd try and stretch out your oney as far as possible. Tons of simple cheap and effective mods will go far. THigns like fender turn signals($30), tint (200), new mesh grill($10), removing badges (couple bucks), Some silverstars up front (60 bucks), some custom seat patches from me($10), and ofcourse, there are tons of things you could do for a couple 20 spots with LED's. WIsh I had 1200 buckaroos to pimp out a tour.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 5,882 |
Originally posted by jmsmathis: i am looking into gitting a 98 tour se v6 5-speed in a couple of months and i will have some $ to drop into it...the reason for this post is to get everyones input on my own thouights..i was going to get the svt body kit but after seeing how expensive the full kit is i have decided to go more on the performance side of it..
why not just get an SVT? i think you might wish you had later.
Posts: 9,602 |
Originally posted by 99_SE: from what i gathered from the search feature, it allows the engine to rev up quicker and therefor make the engine reach max power faster... is that right?
A DMD. No...
You need to search a LOT better!
It's an NVH mod used to reduce vibrations in the 400HZ range. That's the range you most "feel" when driving.
It will actually cause the engine to rev slower being that it is 2+ lbs heavier then the stock damper.
With it having slightly more mass it will make the engine feel torquier in the lower rpm levels.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 405 |
Tony Datsenko
