#1093073 11/01/04 10:10 PM
I replaced the left and front motor mount on my 95 gl 4cyl automatic and I still get a bad vibration when I have the car in gear. The steering column vibrates like crazy. Anyone know what could be causing this? The vibration is gone when the car is moving.
#1093074 11/01/04 10:11 PM
I learned to get used to it and I replaced all the mounts including the tramsmission one. So.. i dont know what to say...
___________________________ '95 Contour GL 2.0L (170K) A/T
#1093075 11/01/04 10:13 PM
How many mounts are there on the 95 gl auto?
#1093076 11/01/04 10:26 PM
i think 5 total ?? not quite sure now
#1093077 11/01/04 10:51 PM
I fixed my timing, and the vibrating went away, very weird, i feel the car stalled at stops now... im used to the vibrating
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
#1093078 11/01/04 10:57 PM
5???? sounds like overkill. I'm used to honda's that use three or four at the most.
#1093079 11/01/04 11:17 PM
H
H
I was told by a few shops that some vibration is normal with these cars and it is unfixable.
Anyways new plugs, wires, air/fuel filter, PCV valve, cleaning the TB/intake, injectors flushed, and using Valoline oil it idles better than when I first got it.
#1093080 11/01/04 11:25 PM
I dont remember exaclty now but i think its 4 and the fifth is on the transmission.
#1093081 11/02/04 02:25 PM
mounts
engine MOUNT, Contour, Mystique, Right - 2.5L 95-97 $188.29 $150.63
engine MOUNT, Contour, Mystique, Left (Front), Auto Trans - 2.5L 95-97 $071.38 $057.10 ... 19.99
tranny MOUNT, Contour, Mystique, Left (Rear), To Crossmember, Auto Trans - 2.5L 95-97 $092.87 $074.30 ... 24.99
tranny MOUNT, Contour, Mystique, Left (Rear), To Fender Apron, Auto Trans - 2.5L 95-00 $111.59 $089.27 ... 69.99
F5RZ-6038-D mount list price $74.95 your price $56.21 in stock
F5RZ-6068-E mount list price $97.52 your price $73.14 in stock
0000 MOUNT, Contour, Mystique, Right - 2.5L 95-97 $188.29 $150.63
2886 MOUNT, Contour, Mystique, Left (Front), Auto Trans - 2.5L 95-97 $071.38 $057.10
2887 MOUNT, Contour, Mystique, Left (Rear), To Crossmember, Auto Trans - 2.5L 95-97 $092.87 $074.30
2873 MOUNT, Contour, Mystique, Left (Rear), To Fender Apron, Auto Trans - 2.5L 95-00 $111.59 $089.27
BAT, Inc. Headquarters
7630 Matoaka Rd.
Sarasota, FL 34243 USA
(941) 355-0005 fax (941) 355-4683
Sales and Technical Service available
Monday-Friday 9:00am to 5:00pm EST
Transmission Mounts 2.5L V6
Transmission mounts are showing signs of wear on higher mileage cars, or
hard use, causing uncontrolled drivetrain movement usually felt as increased
"torque steer". In more extreme cases CV joint or axle failure can occur.
Replacement is simple with these complete mount assemblies. See below
for manual transmission (early and late) and auto transmission listings.
Trans Mount 95-95 MT K433T $98.30
Trans Mount 97-01 MT K433TL $115.00
Trans Mount 95-01 AUTO K433TA $105.30
#1093082 11/02/04 02:28 PM
and some sub frame bushings near front corners of the car which I have not yet installed for I am waiting for another part before I see the shop guy again.
F5RZ-5A103-B $11.57
F8RZ-5A103-BA $15.65
