The remote turn on wire from your amp should be connected to the remote turn on from the radio. If its an aftermarket radio it will be a blue wire, you can use the power antenna wire. Don't use a constant 12 volts source cause your amp will be on all the time. The antenna wire is better because it recieves a signal from the radio not the ignition as to when to turn on.
