Well 149,967 to be exact as of this momnet.
I changed the Air Temp Sensor
I changed all the spark plugs
PCV valve changed by a oil change place - 15.00
They had a "fun" time changing that. They broke the connector the crank sensor (they had to goto the junk yard and get one)
Then the PCV hose got lose and created a vacuum leak.
All fixed and running fine now.
Also noticed that the steering wheel does not vibrate as much when the A/C or defrost is ran either
Hopefully things will run good for a while
