Posts: 21,653 |
Does the tensioner need to be replaced? Get the gatorback belt. Other belts just aren't as good. I still need to get one cuz my belt slips when it's cold.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,725 |
I had my belt replaced twice by Pep Boys ( screwd it up the first time), anyways the belt was $26 I though it was a great deal, now it squeals again, and it looks it bad shape, it was repalced less than a year ago. Buy Motorcraft, more expesnive, but they last and stay quieter a lot longer.
Posts: 937 |
Originally posted by Kremithefrog: Does the tensioner need to be replaced? Get the gatorback belt. Other belts just aren't as good. I still need to get one cuz my belt slips when it's cold.
Well.. I'm at 95K Miles and I still have the same Tensioner. I also have the same timing belt and so I'm worried it will go any year now.
I had a new Gates Belt put on about a year or 2 ago and it helped a lot. The place at that time said my Tensioners was fine.
How much does a new Tensioners cost? And how hard would something like this be to replace on my own?
I was reading up on the GatorBack belt and it looks cool.
Posts: 21,653 |
The tensioner doesn't cost too much. Check your other pullies while you're at it. www.fordpartsonline.com Yeah you mite wanna go ahead and get your timing belt replaced. Everything is easy to do on our cars IF you have the right tools.
98.5 SVT
Posts: 37 |
I did mine from the top. Put a floor jack with a piece of wood on it under the engine and jack it up slightly. Remove the motor mount on top of the engine to get to the belt easier. Replaced the tensioner($56 at a NAPA store), the idler pully($28 at Autozone), the belt ($28 at Autozone). You need a T40 TORX bit on the tensioner. A 13mm and I think a 19mm deep socket for the motor mount. Getting the new belt on is tough UNLESS you put it on BEFORE putting the idler pulley on. The idler pulley goes on EASILY if you just push the belt down while putting it on.
Doug
'96 Contour ZETEC
T-Red/ATX
CEG road warrior
CEG road warrior
Posts: 17,248 |
Used a serpentine belt tool (15mm bolt on tensioner) and slid the belt off. Installed it the same way (had to remove the motor mount and jack the motor up because of S/C).
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 205 |
 Man, I wouldn't pay anyone to work on my car unless I was physically incapable of doing it myself. All together, it only took me about 45 minutes to an hour to get this all done with the help of my brother, start to finish, and that includes the trip to the parts store. I used a Dayco 5060735 that I picked up from Checker Auto Parts, and I haven't had any problems with it at all. Just keep it simple and take your time, and you'll be fine.
P.S. I knew that your supercharger would throw a curve at you somehow, Hector
92 Talon TSi AWD
DSM= Daily Scheduled Maintenence
Posts: 2,725 |
I wouldnt replace the tensior unless it was broken, why bother to fix it if it isnt broke. I dont really see that as maitnance item, as they last a long time.
Posts: 21,653 |
Originally posted by HITMANinMI: I dont really see that as maitnance item, as they last a long time.
HAHAHAHAHA. I love your jokes!
98.5 SVT
Posts: 137 |
ok, well i just replaced my serpintine belt maybe a month ago, with the goodyear gatorback belt, i thought that would stop the squeelling problem on cold mornings, and when your going very slow turning your steering wheel, so the p/s thing takes alot of power, and i thought that was why it was slipping. but it still does it more often then not, so now i think i need to replace the tensioner, or something. what should i change and how hard would that be to change the tensioner? thank ya!
WTB:
Andy's Auto Sport front bumper only...
a chip for my 98se
