#85735 02/01/02 08:46 PM
Bumpin Offline OP
I have two MA Audio Subwoofers model number P120 XL for sale. I have a box that fills the trunk of a 98 ford contour se and it fits perfectly. If you don't want that box then I have another smaller one that was built at Ovation and cost me 230 for the box that I will give with the subs. The box choice is up to you. These subs hit 143 db in the old smaller box, and an estimated 146-148 in the new bigger one. Wanting to sell in the louisville area so no shipping is involved. If interested just post message or e-mail me at matthew_holbrook@hotmail.com
Specs:
240 oz. double stack strontium magnet for high power, high stroke, 1000 watts RMS Power Handling, 2 In. foam surround for long throw excursion, Long dual 3 In. black aluminum voice coil for power handling, control, Vented magnet structure for better heat dissipation, Heavy duty non-pressed paper cone for more solid bass, higher SPL, Chrome post terminals for better connection during hard hitting bass, Chromed aluminum diecast basket, Dual 6 ohm voice coil which maybe connected in parallel to create a 3 ohm subwoofer or in series to create an 12 ohm subwoofer, Rubber sealant gasket
"Reality is Overrated"
www.teamsynthetik.com
"If it is to loud you are to old"
#85736 02/01/02 08:51 PM
Make sure you post this in the Classifieds as well. This thread will be locked shortly.
Moderated by  dnewma04_dup1
