Posts: 14 |
Bought the obd2 scanner from CT.(On sale $175 right now) The scanner doesn't seem to fit properly the the DLC under the dash. Looks like the pins don't match up. Do you have to buy a special cable to use with ford?
1998.5 Ford SE Zetec 2.0 auto 190km
"What do you do for recreation?"
"Oh, you know, the usual. Bowl, drive around, the occasional acid flashback."
Posts: 2,807 |
OBDII is standard across all manufactures. Are you sure you have the correct plug?
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 14 |
Looked like the right plug...but i could be wrong...I only saw one plug running down the left side near the door ...right above the fuel reset button.
Posts: 67 |
Bought the same thing about 2 months ago (the previous sale) and it works like a charm. Had no problems hooking up the thing to my tour, a neon (I know, I know) and a jeep. As far as the connector goes I think it's the same for all cars (manufacturers), but each manufacturer is using the pins a bit different.
One weird thing ... the tour responds to reads and resets at least 5 times faster than the other cars...
Hope this helps.
98.5 SE,V6,MTX
205.000km
Posts: 67 |
Originally posted by steve_the_dude: Looked like the right plug...but i could be wrong...I only saw one plug running down the left side near the door ...right above the fuel reset button.
That's the right one...
98.5 SE,V6,MTX
205.000km
Posts: 14 |
I was in a rush to try it out before going to work. didn't seem like it plugged it...test her again tomorrow.
Posts: 715 |
Originally posted by steve_the_dude: Bought the obd2 scanner from CT.(On sale $175 right now) The scanner doesn't seem to fit properly the the DLC under the dash. Looks like the pins don't match up. Do you have to buy a special cable to use with ford?
DAMN IT!!! what is CT's policy on price protection I bought mine not too long ago cause I really needed it and I payed full pop!!! I knew this would happen!!!
Brian W. -------------------- Black 1998 SE 5 speed - TOTALLED
Posts: 715 |
Done, I got the difference!
Posts: 14 |
Sweet...didn't know you could do that at CT
Posts: 715 |
I work in retail, I knew you could do that anywhere. They only do price protection for 14days, mine was 19 days but she did it anyway.
