#1088113 10/26/04 07:38 PM
Bought the obd2 scanner from CT.(On sale $175 right now) The scanner doesn't seem to fit properly the the DLC under the dash. Looks like the pins don't match up. Do you have to buy a special cable to use with ford?
1998.5 Ford SE Zetec 2.0 auto 190km "What do you do for recreation?" "Oh, you know, the usual. Bowl, drive around, the occasional acid flashback."
#1088114 10/26/04 08:32 PM
OBDII is standard across all manufactures. Are you sure you have the correct plug?
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
#1088115 10/26/04 08:41 PM
Looked like the right plug...but i could be wrong...I only saw one plug running down the left side near the door ...right above the fuel reset button.
#1088116 10/27/04 02:22 AM
Bought the same thing about 2 months ago (the previous sale) and it works like a charm. Had no problems hooking up the thing to my tour, a neon (I know, I know) and a jeep. As far as the connector goes I think it's the same for all cars (manufacturers), but each manufacturer is using the pins a bit different.
One weird thing ... the tour responds to reads and resets at least 5 times faster than the other cars...
Hope this helps.
98.5 SE,V6,MTX 205.000km
#1088117 10/27/04 02:27 AM
That's the right one...
#1088118 10/27/04 02:48 AM
I was in a rush to try it out before going to work. didn't seem like it plugged it...test her again tomorrow.
#1088119 10/27/04 02:55 AM
DAMN IT!!!
what is CT's policy on price protection I bought mine not too long ago cause I really needed it and I payed full pop!!! I knew this would happen!!!
Brian W.
Black 1998 SE 5 speed - TOTALLED
#1088120 10/27/04 09:23 PM
Done, I got the difference!
Brian W.
#1088121 10/28/04 03:34 AM
Sweet...didn't know you could do that at CT
#1088122 10/28/04 01:27 PM
I work in retail, I knew you could do that anywhere. They only do price protection for 14days, mine was 19 days but she did it anyway.
Brian W.
Moderated by  Gerald_dup1, mbb41_dup1
