Posts: 319 |
I need to know how to fix my horn. is it fixable? maybe it just a loose wire or connection or something. If it cant be fixed easily i'll go to a junkyard i guess. my horn has a wavering noise. its a blunt low buzzing noise now when i use my horn, but it sometimes becomes more high pitched. sometimes it actually sounds normal. it also seems to vary its pitch depending on what area of the horn pad i touch. does this sound like a problem with the pad? im baffled. dont even know where to start
'98.5 Black Ford Contour SE Sport 5-speed. All the SE Sport features with all the 98features that were supposed to be decontented for 98.5
'04 Silver Toyota RAV4 L Auto. Fully loaded.
Posts: 6,910 |
i suppose the horn could have a crack in it or something
since I see in your sig that you have many 98 features do you have two horns or just one? if you have two only one might be having an issue
if not you can go and get a matched set of FIAMM freeway blasters, sounds like stock pre98 horns and install them on your car
- 95 Mystique LS - Zetec/5spd
Posts: 319 |
as far as i could tell its only one horn. it sounds like either its cracked or has something lodged in it. im thinking maybe something just came loose. it started off with just a slight change in pitch that only i noticed and got much much worse. the horn is low on the drivers side of the car. in front of the wheel, just inside the bumper. i want to remove it and inspect it, but i havent been able to find a big enough window where it was dry outside. my garage is just too tight to work in
Posts: 2,382 |
Probably just worn out. The internals are beginning to seize up at times and that creates the warble you hear. They are sealed units and cannot be fixed. (OEM's that is)
Autoparts stores sell a variety of replacments. I used to have a set of air horns, loved them!
"Fear is the little death."
Muadib.
Posts: 1,456 |
Just replace it, corroded inside.
Posts: 5,143 |
Eh, the contour isnt very well spoken for... Everytime I use it with my friends in the car they just laugh their asses off at it. if it ever breaks... all I need is one thing, My finger
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 49 |
