Posts: 35 |
I get alot of vibrations from the steering wheel, while in gear at a stop light.
It gets really bad, when the defrost or A/C is running.
I just put on a new fan belt about a month ago.
Could it be a pully or a tensioner?
It runs fine when i give it gas and head on my way after the light turns green.
Posts: 3,395 |
Same here, hows your gas milage?
Posts: 2,725 |
There is a TSB for this, something about radiator mounts.
Mine does it to, however cleaning the TB and intake helped cure it.
Posts: 937 |
To be honest it can be many things...
1. Engine or Motor Mounts 2. Serpentine belt 3. Belt Tensioner 4. Serpentine pully
Common for the Contour 4 cyl. The Radiator was designed to "float" in its mounts. Some of the vehicles got out of the factory with radiators that were too tight in its mounts. The normal engine vibrations were transferred through the cooling system to the radiator core support. Ford provided new radiator mounts and bushings in a TSB fix. Before the parts came out, I would bend the lower mounts down to looses up the fit of the radiator.
Posts: 35 |
Just replaced the Serpentine belt, about a month ago.
Could it be my tensioner or pully?
CEG road warrior
CEG road warrior
Posts: 17,248 |
All Zetecs vibrate.....
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 2,086 |
My 97 Mystique does the same thing and i test drove a contour the same year same engine the same day i test drove my mystique and it also did it but one of them was worse then the other i cant remember which one it was.
Jason G.
--------------------------- Pacific Green/Teal Mist 97 Mercury Mystique, Aiwa CD Player, 4 Pioneer 220 Watt 6X8 3 Way Speakers, with 98+ Spoiler.
Jason G.
Born: 11/96
CEG road warrior
CEG road warrior
Posts: 17,248 |
All Zetecs vibrate....and all of them tick.
Hector
257HP/259TQ
160HP/141TQ
Posts: 393 |
ding
