i just got my gauge pod from lo-tek @ www.gaugepod or
www.gaugepods.com. its the same company. yes they are a little off color from the midnight blue in my svt but its pretty close from out side of the car looking in i can't even tell a difference.
i got autometer gauges, a lot of ppl at least from the post that i have read had trouble with the oil pressure gauge sender unit into the head . with the auto meter sender and the 1/8 fitting adapter that canme with with the gauge in the box install was no sweat. just a little teflon tape . for the treads.
getting the plug out of the head was about the trickyest part. i used a 1/4 standard style allen hex socket bit that seemed to fit just perfect.
tapped the white wire with the red stripe, lol " red- stipe" in the front bank o2 sensor after the green conector right next to the windshield wiper refill tank.
hooked the back light bulbs to the head light switch, using a test light to tap the right wire. and the 12 volt + and the ground are hooked up to the head unit/cd player.
i would post pics but if you've seen one triple gauge pillar in an svt you've seen them all. i got silver gauges which match the color of my car more than they do my stock white gaues but nevertheless their kool.
