Posts: 8 |
I don't know much about engine work I usually do stereos. But I need to know where I can find the compression ratio for my car. I drive a 95 Contour with the Zetec engine. Help me please!
1995 Contour GL
17" Enkei CDR9 205/40 Toyo tires
Intrax Springs
CTA Motorsports Intake
Pioneer CD Player, 2 12" PolkMomo Subs, and Audiobahn amp
Reverse Glo Gauges, and 3" tachometer on dash
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 242 |
9.6:1 i think it says in my Haynes
Posts: 8 |
Thanks for the help guys. I really appreciate it.
1995 Contour GL
Intrax Springs
Posts: 8,143 |
are you serious, is that not almost perfect for boost? i thought we had like a 10:1 or 11:1 compression ratio
Posts: 862 |
heres the real question, what can be done to make our zetecs perform. Currently they are below the level of lesser displacement engines aka 1.8dohc in integras produce 140hp and our 2.0dohc produces 125hp. Since the compression ratio is almost the same and they are both dohc, what the heck is the deal. I know there are more differences, but come on.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 21,653 |
There are a lot more differences, also we have more torque.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 862 |
yes I said that, but what are the ones that effect the difference in power?
Posts: 21,653 |
What does it matter? I mean, it's not like you can really redesign the engine. One thing they rev higher. All engines are different, different cams, different pistons, different valves, different intake and exhaust manifolds.
98.5 SVT
Posts: 862 |
well of course you can't redesign it, but you can change things like compression ratio, pistons, ect. Maybe its the rod ratio or stroke, something definately makes the difference and I am curious what it is.
