Posts: 206 |
Hi everyone, I searched but could not locate a solid answer. The power steering fluid used (98 SVT) is Mercon I believe. Can we use Mercon V in there instead or does it have to be Power Steering fluid to use it? I used it in my tranny and boy what a difference. I was hoping for that same effect in my steering.
Posts: 1,145 |
dont know if you can use it for the steering, but i do know the power steering system does not use power steering, it uses ATF but dont know what kind, let me run and check really quick
98.5 Black SE ATX
Posts: 1,145 |
ok after some searching i found some of the fluids you can use
you can use Mobil 1 synthetic ATF or any other mercon type fluid, mercon v is different so i dont know if it will work.
dont use ATF type F, that is only for the earlier contours, not the later ones.
Valvoline Synpower power steering fluid can also be used.
some have also used AMSOIL Synthetic ATF fluid
98.5 Black SE ATX
Posts: 9,602 |
I highly recommend Mobil 1 ATF.
Less parastic drag, better thermal protection, and longer service life. The P/S pump spins excessively fast above 4000rpm.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 206 |
Well the reason I was so interested is also because I still have about 2 qts of Mercon V in my garage. I know both the tranny and power steering require Mercon and Mercon V meets this standard and it worked good in my tranny.
Posts: 206 |
Anyone else have any input on using Mercon V in the power steering? Thanks
Posts: 7,117 |
Originally posted by BBContourSVT: Anyone else have any input on using Mercon V in the power steering? Thanks
For the power steering Mobil 1 ATF is your best choice.
For the tranny DO NOT USE MERCON V !!!!!!!!!!!!!!!!!! The manual specifically says do not use it! It's hidden, but it is in there! Use regular old Mercon.
