i've just bought a 24mm sway bar in the classifields and did not realize what i was getting my self into.it seems i've opened a can of worms .its all in the best of intentions.
ok so i've got a 24mm aussie sway bar just the bar without the bushings or brackets or reinforcements.
while searching i believe i found all the parts needed but have no idea of what the part#'s are or where to get them from.
frist question- by any chance can i get everything i need from stazi ? does he still make the reinforcement plates and supply all the needed bolts and bushing and brakets ?
-just a shot in the dark-
if thats not the case were can i get -
-24mm aussie sway bar bushings >?
-brackets for the sway bar?
-reinforcement plates?
from what i've read this is a great mod if installed correctly .i want to do this right the first time , i understand the subframe needs to be welded . and that i want to use poly bushings.
the only pics i could find are these-
http://www.pbase.com/cdw27/gallery/ati any help in this field would be greatly appreciated.
the more pictures/drawings,personal stories the better. i'm affraid the subframes has to be removed to install this beefy bar right the first time.
