#1077326 10/13/04 09:08 PM
Does anyone have information on how to tell me how to fix a rear wheel bearing? I think my passenger side rear one is toast, lots of road noise and gets louder when I turn to the right, but goes away when I turn to the left....Any idea on part cost either??
Jonathan
#1077327 10/13/04 09:34 PM
TGO Offline
you can't do the bearing yourself, but you can take off the hub and bring it to a machine shop and save yourself labor charges.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#1077328 10/14/04 02:56 AM
N
N
Here's the how to from the ford shop manual.
Removal
Remove the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Using the special tool, remove the wheel hub from the wheel knuckle.
Remove the inner and outer circlips.
Press out the wheel bearing.
Installation
Install the outer circlip.
Press in the new wheel bearing.
Install the inner circlip.
Install the wheel hub to the wheel knuckle.
Install the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
#1077329 10/14/04 02:07 PM
Can a rear wheel bearing be put back on again after it has been removed? I heard that once a wheel bearing has been pressed off, it becomes unusable.
#1077330 10/14/04 05:32 PM
E
E
Rear Wheel Bearings are easy. The replacement part is the entire hub assembly. Just pull the wheel off then pull the hub off (32mm socket) and replace it with a new assembly. I bought 2 for under $100.00 from Napa. The job took under 1 hour for both sides.
1998.5 E1 SVT Contour #5482/6535
#1077331 10/14/04 05:45 PM
I just saw that on AutoZone, $34.99 for the rear hub/bearing assembly....Thanks alot!!!
Jonathan
#1077332 10/14/04 05:47 PM
Come to think of it, is that what is wrong??? I mean, alot of road noise?? Like you can actually hear the wheel going around and when you turn it gets louder??? The rim back there has a small dent but would that cause it??
From reading prior threads I assumed it was a wheel bearing!
Jonathan
