Page 2 of 2 1 2
#1075029 10/12/04 02:53 PM
I don't think we are talking abou the same car unless you are from the Woodstock/ kingston NY area. There is so much to read about for this engin swap, I am so confused as to what to do. I want to do the hybrid, but maybe the whole 3L would be better. Plus if I but a SVT with a blown motor and then can't use most of the parts that i need, I need some advice!! I really want to work on this during the winter. I just don't know what to do if the cams are finished and any other parts on the blown motor, It will probly start to get very expensive.?!
2003 Dodge Ram 2500 Cummins stock
#1075030 10/12/04 02:55 PM
Captain Impound Boy
Captain Impound Boy
Maybe not this one is in NJ or soemthing. What color is it?
If you have never worked on a engine it could end up being a hassle. don't know you or your abilities
#1075031 10/12/04 03:19 PM
I havent worked on engins before, but i know two people who have. I just know the basics of working on cars. Oh the car Im looking at is silver, and NOT in NJ, but I did see that one. I did just read Buckshots site and I may just try to buy a motor from him, but I have to do some E-mail to him first. I would rather buy my own motor and use the parts from the blown motor instead.
#1075032 10/12/04 04:12 PM
Since you're having a hard time, I'll see if I can help a little.
There are probably 3 or more options with 3L. The biggest difference between these depends on what heads and LIM you use. You can use the SVT 2.5L "split-port" heads, or the "oval-port" heads that are used on all 3L Duratec vehicles (escape, tauras, etc). The 3L oval port heads will use the additional drainage holes that the 3L block has, but that the 2.5L block does not have. If you use the oval port 3L heads, you can either use the 3L LIM and connected intake parts, or modify the heads to accept the split-port SVT LIM, and use the SVT intake parts. Here are some example setups:
SVT Hybrid - This setup uses a 3L shortblock, 2.5L SVT heads and cams, everything up from there is all the SVT parts (LIM, fuel rail, UIM, etc). Generally, if your heads are in perfect shape you only have to swap those heads onto a 3L shortblock, plug a couple oil lines, and done.
Full 3L #1 - This setup uses a 3L shortblock with the 3L oval port heads , which can be modified to accept the SVT split port LIM, then use your SVT fuel rail, UIM, etc. I beleive this is the setup DemonSVT is using and probably has the fastest N/A contour.
Full 3L #2- This setup uses a 3L shortblock (actually, this is technically a longblock) with the 3L oval port heads, the 3L LIM, fuel rail, and goes right on up with a 3L UIM, TB, etc.
The thing is you can buy a full used low-mileage 3L longblock with heads, LIM, UIM, all of it for less than $1000. You can also buy a brand new 3L shortblock with warranty for just under $600.
I went Hybrid because I thought it would be cheaper, but for me it didn't end up being any cheaper at all because I had to buy SVT heads and cams and the other SVT goodies that I didn't have. All timing parts from your SVT can be used on the 3L, just don' mix and match 3L and 2.5L timing parts becuase they won't work together (different sprocket sizes).
EDIT: Remember, much of what route you take here will probably depend on what parts you can still use from the blown 2.5L engine. If the heads are fine, you can do a hybrid. If they're not, it will probably be more economical to go with a full 3L option. Bottom line is you probably won't know until you tear down that blown motor.
#1075033 10/12/04 04:29 PM
Thanks for all your input. I guess I have to ask what went wrong with this motor that im looking at. But even if I buy this SVT and find out I can't use most of the parts, still $500 is a good price for a SVT and it is in good shape. I guess I will just have to play it by year. Again, Thank you for all the information, and thank you to all others who have been helping me out!!!!
#1075034 10/12/04 04:34 PM
Originally posted by contour21:
play it by year.
#1075035 10/12/04 05:44 PM
urr..play it by engin condition!...
#1075036 10/13/04 01:10 AM
err play it by EAR. And it's spelled engine.
#1075037 10/13/04 02:07 PM
Ok I can't spell, and I guess I just have no clue what Im talking about! LOL I get it right sooner or later!!
Page 2 of 2 1 2
